AutoCAD Forum
Layer filter messages
1 REPLY 1
BeKirra
264 Views, 1 Reply
I recieved a drawing and every time I open it a message showed in the command line:
Opening an AutoCAD 2013 format file.
Regenerating model.
AutoCAD menu utilities loaded.._-layer
Current layer:  "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: filter
Current layer filter: "All"
Enter a layer filter option [New/Set/Rename/Edit/Delete/eXit]: set
Enter layer filter to make current: Mech_1
Layer filter not found.
Command:
Autodesk DWG.  This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
Command:
There is no layer filter in the layer manager.
The current layer state is "_LAYISO_STATE" in model space and "Same as DWG" = "No".
I know that the layer filter "Mech_1" has been removed and most likely some of layers were delected with the filter.
How to prevent the message pops up again when opening the drawing?
Thanks for your help.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
1 REPLY 1
pendean
in reply to: BeKirra
Looks like you are running a custom startup: yours?
Or by chance is there an acad.lsp file that suddenly showed up in the same folder as this file?
”Boost
