AutoCAD Forum
Large file size
7 REPLIES 7
Message 1 of 8
MadhuDas
327 Views, 7 Replies
Large file size
I am using AutoCAD 2014. I have several drawings having large file size but very less drawing objects (may be due to hidden proxy objects).
In AutoCAD-2010 I have successfully reduced the file size simply by copying the content and pasting to a new file. The same thing is not working in AutoCAD-2014. When I copy even a single line and paste to a new file, the file size comes to around 4MB. I think the new versions of  AutoCAD copies the hidden proxy also along with drawing entities. Is there any way to avoid this?
7 REPLIES 7
Message 2 of 8
ennujozlagam
in reply to: MadhuDas
hi, I've tried your drawing and reduced the size. Just dxfout and dxfin again. command>Purge>audit>scalelistedit. hope it helps. thanks
Message 3 of 8
nestly2
Try using WBLOCK instead of copy/paste.  Reduced file from 4.4MB  to 72KB
Export objects to drawing file with WBLOCK command  (method #2 or method #3)
Message 4 of 8
braudpat
Hello
My version : 49 Kb
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 5 of 8
ennujozlagam
in reply to: braudpat
Hi Pat,
Have you try to open and save from autocad 2014 and see what is the difference in file size?
Message 6 of 8
braudpat
in reply to: ennujozlagam
Hello
I have purged from ACAD 2015 (It's better) because of the New option to erase DGN Unused LineTypes !
So I haven't to use the specific Tool for 2013/2014 :
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD...
And then I have cleanup the DWG with multiple specific tools ...
Patrice BRAUD
Message 7 of 8
ennujozlagam
hi Pat.
Okey see what you mean, thanks and regards
Message 8 of 8
shavezkhan
simply use exportautocad command & see
”Boost
