AutoCAD 2013/2014/2015
jtomkinson
Message 11 of 16 (475 Views)
Re: Laggy Command Line
09-26-2012 09:34 PM in reply to: jtomkinson
Installing SP1 appears to have fixed the problem.
New Member
mark.doel
Message 12 of 16 (442 Views)
11-07-2012 01:29 AM in reply to: jtomkinson
we are still having problems with this even with SP1 installed
type Z and hit return quickly and we get unknown command, similar problem with L
If the users pause for a second before hitting return the list of command options for that letter appears but there is a definate lag
GTVic
Message 13 of 16 (428 Views)
11-07-2012 10:05 AM in reply to: mark.doel
Maybe a bad LISP reactor routine. If the problem occurs for everyone in your firm then I would say the best thing to do is start with a generic install and build up your config manually and test at each step.
GT
Active Contributor
chughes
Message 14 of 16 (337 Views)
03-01-2013 01:33 PM in reply to: GTVic
I have the exact same issue, a very noticeable lag when inputting commands when the Command Line is visible.  If I turn the command line off (Ctrl-9) there is a huge improvement in perfomance.  I have tried running with the text window (F2) open on a secondary monitor, but it doesnt stay on top of all windows all the time.  Having the text window open does not affect performance.
Has anyone come up with a solution since the last post?
Distinguished Contributor
itr0045
Message 15 of 16 (219 Views)
07-29-2013 06:45 AM in reply to: chughes
I have been struggling with this issue since installing 2014.  I feel this issue is exclusive to 2014, but I am hesitant to call it a "feature".  The delay is enough to mess up a command and to an efficient user of CADD this is a problem.  Hotkeys are rendered somewhat useless and I am forced to slow down my typing in order to execute the correct command.  I have installed all hotfixes and service packs as well and none have resolved this issue.
itr0045
Message 16 of 16 (197 Views)
07-29-2013 09:58 AM in reply to: itr0045
I have discovered that this issue is best resolved with turning the "Dynamic Input (F12)" off.  I am glad that I finally have this issue fixed as it was driving me nuts since install.
