Hello all,
Does there any way that the main file will keep in "memory" the locations of it's Xrefs?
I moved the file to a different folder and I want it's Xref's to automaticly appear in it...
Thank you in advance,
If you put the xrefs in the same folder with the drawing it will find them. If you need to keep separate folders you can batch change the xref paths by going to Windows start button, All programs, Autodesk, AutoCAD, Reference manager.
With some minor exceptions....
Much more detail on the topic can be found here.
An alternative to the xref manager is the "Redir" command. (Before running it, use windows to browse to the new folder location and copy it to the clipboard) When prompted with "Replace "*" with:" paste it in.
