AutoCAD Forum
JOIN LINE AND POLYLINE AND IT CREATES A SPLINE? WTF?
5 REPLIES 5
JA5.15
3997 Views, 5 Replies
Joining a line and a poyline containing a polyline arc creates a spline now? I don't believe I've encountered this behavior before? Why can't it just create a polyline? If I convert the spline back to the polyline it now has 1000000000000 vertices in the arc, instead of a standard polyline arc? Is this a variable somewhere? Or is this standard and somehow I missed it the last x number of years?
5 REPLIES 5
rkmcswain
in reply to: JA5.15
Re: the line+pline join = spline
I cannot recreate this in 2015.
pendean
in reply to: JA5.15
Not in 2014-2013 or 2012 here either.
Method of "joining" is...?
Any chance you have a DWG file where this occurs that you can post here?
nestly2
in reply to: rkmcswain
When a line and pline are not created on the same UCS
... or when the pline has been rotated out of it's original plane
... or when the pline and line are non-coplanar
AutoCAD2011 JOIN command will not join
AutoCAD2012 JOIN command will join and convert to 3D poly and "straighten" curved segments
AutoCAD2013-2015 JOIN command will join and convert to Spine
rkmcswain
in reply to: nestly2
Good to know. Thanks.
JA5.15
Interesting, thanks Nestly2
”Boost
