AutoCAD 2013/2014/2015
New Member
0 Kudos
Post 1 of 3
Issue of commands
156 Views, 2 Replies
12-05-2012 08:16 PM
Hello all,
  Im still learning and trying out the autocad 2013, I do not know what did I triggered but whenever I try to move a object, everytime after i select the object and enter the shortcut commands 'm' it will required me to re-select the object again. Can anyone tell me how to solve this issue? It's really slowing me down and driving me nuts.
Thank you.
Regards.
What is your PICKFIRST system variable set at?
The PICKFIRST system variable controls whether you can select objects before you start a command.
Type:Integer
Saved in:Registry
Initial value:1
0
Off. You can select objects only after you start a command
1
On. You can also select objects before you start a command
25 Kudos
Post 2 of 3
Re: Issue of commands
12-05-2012 08:52 PM in reply to: dessoul
Type:Integer
Saved in:Registry
Initial value:1
0
1
New Member
0 Kudos
Post 3 of 3
12-05-2012 10:04 PM in reply to: Johneng
Thank you very much!
