AutoCAD Forum
Isometric Ellipse has a Bulge
4 REPLIES 4
RocksterB
413 Views, 4 Replies
Why does creating an isometric ellipse create a bulge in the long radius direction? I should be consistant throughout the offset distance. In the attached image file, I created the two ellipses from the same center point.
4 REPLIES 4
jggerth
in reply to: RocksterB
Are you referring to an ellipse drawn as an ISOCIRCLE?  eg in 2D isometric drafting mode?  or an ellipse drawn in 3D Space with an issometric view set?
RocksterB
in reply to: jggerth
2D isometric drafting mode. 3D is next, but a little down the line of priorities.
jggerth
Then it's being drawn correctly.  the 'true' dimensions in Isometric Drafting are only along the isometric planes.  Attached is an isocircle with a 94 unit diameter,  Smaller one was drawn with the same center.  Between the isometric lines, the curves are interpolated.
RocksterB
I see it, but..., I still don't like it. I'm drawing pipes and it just looks off. Oh well...
”Boost
