AutoCAD 2013/2014/2015
1 Kudo
Post 1 of 6
Is there any script (command) to select all layers?
816 Views, 5 Replies
06-13-2012 03:14 AM
I want to hide all layers through scripting. Firstly I have to select all layers for the same.
So, Can any1 tell me command to select all layers?
with Lisp:
(command "_-LAYER" "_OFF" "*" "_Y" "")
or by typing into command line (and so also within a script)
_-LAYER<ENTER>
_OFF<ENTER>
*<ENTER>
_Y<ENTER>
<ENTER>
HTH, - alfred -
1,213 Kudos
Post 2 of 6
Re: Is there any script (command) to select all layers?
06-13-2012 03:20 AM in reply to: vikasranga2
with Lisp:
_-LAYER<ENTER>
_OFF<ENTER>
*<ENTER>
_Y<ENTER>
<ENTER>
HTH, - alfred -
Alfred NESWADBA
1 Kudo
Post 3 of 6
06-13-2012 03:34 AM in reply to: Alfred.NESWADBA
I run this script. It turn off only current layer, not all the layers.
I need the script, which select all layers and then turn them off.
Thanks.
1,213 Kudos
Post 4 of 6
06-13-2012 03:38 AM in reply to: vikasranga2
My message above shows two ways switching off all layers (including the current one) and that does not work in your environment? Can you show then a copy of your command-line so I can see what happend?
Well, one sitation may be a problem, that is if you start my code while the current layer is already OFF, that may be proofed.
Or do I misunderstand something?
- alfred -
Alfred NESWADBA
1 Kudo
Post 5 of 6
06-13-2012 03:43 AM in reply to: Alfred.NESWADBA
Thanks.
great, it worked.
1 Kudo
Post 6 of 6
06-13-2012 04:27 AM in reply to: vikasranga2
Can I have the command to make filters?
I need to show some specific layers. So, required script to nake filters.
or
Any file having all the commands?
