AutoCAD Forum
is there a setting to adjust attribute text height?
2 REPLIES 2
andrew.nao
281 Views, 2 Replies
ive never had nor seen this happen with any dwg all the sudden this just happened the "1" is an attribute inside of a block and supposed to be small and fit inside the triangle. as you can see in the pic, it is not. is there a variable or setting that i should check for this? thanks
2 REPLIES 2
Jason.Piercey
in reply to: andrew.nao
Is it annotative?
andrew.nao
in reply to: Jason.Piercey
no they are not but checking that solved my issue thanks
”Boost
