AutoCAD 2013/2014/2015
Active Contributor
yuh0317
Message 1 of 4 (171 Views)
Is it possible to plot model and layout in a dwf file?
171 Views, 3 Replies
09-14-2012 07:39 PM
I want to plot model and layput in a dwf file in AutoCAD 2013. So is it possible to plot model and layout in a dwf file?
YU
heinsite
Message 2 of 4 (158 Views)
Re: Is it possible to plot model and layout in a dwf file?
09-14-2012 11:42 PM in reply to: yuh0317
In AutoCAD your Model Space tab *is* your model.  That's the building or site plan or object of whatever that you are drawing.  Layout (also known as Paper) Space is what Autodesk uses to help you print/plot your model.  Within the Layout (Paper) space you create Viewport(s) to see portions of, or all of your model.  When you plot, you plot from the Layout and you'll get whatever you have drawn there.
On the Layout tab, and within the plotting area, you can include anything in addition to the model (as seen through the Viewport) that you might like.  Typically we will put a title block here.  It only shows on this tab (or other Layout tabs) and is not part of the Model.  So it only shows when you print/plot.
A DWF file is simply another type of plot.  You can plot to a printer, to a plotter, to an Adobe PDF file, or to an Autodesk Design Review DWF file.  So the long answer is, "Yes".  Your model (all or parts of it) plus whatever you've added in a Layout can be plotted to a DWF.
Hope this helps.
Dave.
Dave Hein, P.E.
pendean
Message 3 of 4 (136 Views)
09-16-2012 10:27 AM in reply to: yuh0317
Short answer: no, not like AutoCAD, if that is what you want. DWF is a plot, like you do to paper.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
dbroad
Message 4 of 4 (128 Views)
09-16-2012 05:29 PM in reply to: yuh0317
It depends on exactly what you mean.  If you mean plotting the model tab and a layout tab on the same sheet of a dwf file, then no. If you mean on separate sheets in the same DWF file, then yes it is possible.  Plotting model space, typically involves adding a viewport to a layout and scaling it.  Then plotting the layout full size.
