AutoCAD Forum
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Is it possible to move the status bar
3 REPLIES 3
bbslo
2531 Views, 3 Replies
Hello, I teach autocad and would like to move items on the status bar to the top of the workspace (students have trouble seeing it at the bottom when it's projected onto a screen). Does anyone know if that is possible? I would like to move the status bar (or just the row of toggle buttons and coordinates on the status bar) like you are able to move the command line. Given that you can't dock and undock the status bar, as you can the command line, I'm wondering if this is even possible?
Thank you!
3 REPLIES 3
nestly2
in reply to: bbslo
Welcome to the Autodesk forums.
As far as I know, the Status bar location is fixed.  The only solution I can think of is to resize the AutoCAD window so there's some space between AutoCAD and the Windows taskbar.
bbslo
in reply to: nestly2
I think it's fixed too. Thanks so much for your quick responds and suggestion.  I'll give it a try.
doni49
in reply to: bbslo
Have you ever used the Magnifier tool?  It's part of the Acceissiblity tools included in windows.  It's intended for people with eyesight issues.  If you set it up right, it could even serve to highlight one particular part of your screen.
See the screenshots below for a couple different possibilities.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
ā€Boost
