Hello i have a quick question.
I have this exterior wall hatch that was created into 1 single hatch. Now i need to remove half of it to do an update.. I just can't explode it to get separate hatches sections.
How can i transform this entity into multiple entities?
See DWG.
Solved by GrantsPirate. Go to Solution.
First use the recreate boundary option in hatchedit, then use the separate option in hatchedit.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
@Cbitts wrote:
You could also try clicking the button 'create seperate hatches' in hatch edit
Cbitts,
There's something about skipping the step of recreating the boundary that produces funky results when you do that. I understand what it's doing enough to avoid it myself but to try and describe it here? I don't know about that -- much easier to let you try it for yourself.
Try opening the file the OP posted and do as you suggested. Then re-open it and do as GP suggested. See the difference?
Don Ireland
Engineering Design Technician
Another way is to make a polyline around the area that you would like to remove, press trim, select the polyline, and then click on the hatch in the area you would like removed.
Don Ireland
