AutoCAD Forum
Is it possible to explode a hatch into separate haches
7 REPLIES 7
Message 1 of 8
Peac3
9045 Views, 7 Replies
Hello i have a quick question.
I have this exterior wall hatch that was created into 1 single hatch. Now i need to remove half of it to do an update.. I just can't explode it to get separate hatches sections.
How can i transform this entity into multiple entities?
See DWG.
7 REPLIES 7
Message 2 of 8
GrantsPirate
in reply to: Peac3
First use the recreate boundary option in hatchedit, then use the separate option in hatchedit.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 3 of 8
Peac3
in reply to: GrantsPirate
Think i am going to cry
thanks Grants.
Message 4 of 8
Cbitts
in reply to: Peac3
You could also try clicking the button 'create seperate hatches' in hatch edit
Message 5 of 8
doni49
in reply to: Cbitts
Cbitts,
There's something about skipping the step of recreating the boundary that produces funky results when you do that.  I understand what it's doing enough to avoid it myself but to try and describe it here?  I don't know about that -- much easier to let you try it for yourself.
Try opening the file the OP posted and do as you suggested.  Then re-open it and do as GP suggested.  See the difference?
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 6 of 8
Cbitts
in reply to: doni49
I'm not sure what you mean, I thought that he is trying to separate them?
Message 7 of 8
Cbitts
in reply to: Cbitts
Another way is to make a polyline around the area that you would like to remove, press trim, select the polyline, and then click on the hatch in the area you would like removed.
Message 8 of 8
doni49
in reply to: Cbitts
Yes. He's trying to separate them. Try opening his file and do as you suggested. Not good results.
Sent from my Android device with K-9 Mail. Please excuse my brevity.
Don Ireland
”Boost
