AutoCAD Forum
is it autocad2014 bug?
3 REPLIES 3
jhkwon
409 Views, 3 Replies
hi  i use autocad2014 mechanical and autocad2014LT (language korean)  OS:windowXP 32bit
Enter the command window tr(trim)
tr..enter
tr..enter
tr..enter
tr..enter
1 to 10 times, command bar  t (text)
i want tr(trim) command but enter t(text)
not problems  keybord , not mistake typing
so Minor problems... but very angry 😞
T . T
Tags (2)
3 REPLIES 3
pendean
in reply to: jhkwon
<enter> using the keyboard key, or your mouse' right-click button?
Are you positive TR is set to TRIM in your AutoCAD session? It can be changed easily.
GrantsPirate
in reply to: jhkwon
Others, including myself, have noticed this problem with 2014. About the best you can do is set AUTOCOMPLETEDELAY to 1000 (1 second) or higher.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
pendean
in reply to: GrantsPirate
INPUTSEARCHDELAY is the current name for that variable in 2014.
”Boost
