AutoCAD 2013/2014/2015
noli1057
Message 1 of 6 (76 Views)
Is AutoCAD2014 can create surfaces by milti points location?
76 Views, 5 Replies
08-13-2014 12:46 PM
Is this possible in plain AutoCAD? Coz one of our PM requiring me to generate surface area of existing grade with provided point of elevation/location. And then extruded down with a level elevation to get an accurate estimated volume. Thanks for any response.
JGerth
Message 2 of 6 (70 Views)
Re: Is AutoCAD2014 can create surfaces by milti points location?
08-13-2014 01:50 PM in reply to: noli1057
lots of work involved in doing it with vanilla.  thats' where a real civil package comes in,  Civil3d  for one option.  Carlson for a less expensive choice that _may_ be easier to get going with.
dgorsman
Message 3 of 6 (61 Views)
08-13-2014 02:29 PM in reply to: JGerth
And along with the advanced tools comes more complexity.  Unlike AutoCAD, trying to "jump right in" with Civil3D will lead to hair loss, forehead-to-monitor/keyboard contact, and various and sundry other conditions.
If a high level of accuracy isn't needed and there aren't a lot of points it can be done with a few steps in AutoCAD:
- break overall area into logical flat areas
- outline with POLYLINEs and extrude to depth
- get volume with MASSPROP or other methods
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
noli1057
Message 4 of 6 (62 Views)
08-13-2014 02:30 PM in reply to: JGerth
Thanks! I tried the LOFT command approximately connecting point with line to generate surface but its not looks good. I will ask the PM's for a Civl 3d CAD base. Thanks a lot.
vladimir.michl
Message 5 of 6 (38 Views)
08-13-2014 09:57 PM in reply to: noli1057
You can also try the freeware utility "DTM" to create a basic terrain surface from 3D points. See http://www.cadstudio.cz/dtm
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
braudpat
Message 6 of 6 (33 Views)
08-13-2014 10:42 PM in reply to: noli1057
Hello from France
When I have many XYZ AutoCAD Points and I want to create a DTM, I used (since a long time ago) the "nice good old" Triangulate.vlx routine from Elpanov - THKS to Elpanov !
I have attached it to my msg ... This routine can run (on any ACAD/AA/MEP/MAP/CIVIL/etc x86 or x64) until a maximum of about 800 000 XYZ points !
I hope this routine can help you !?
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
