AutoCAD Forum
Is AutoCAD2014 can create surfaces by milti points location?
5 REPLIES 5
noli1057
256 Views, 5 Replies
Is this possible in plain AutoCAD? Coz one of our PM requiring me to generate surface area of existing grade with provided point of elevation/location. And then extruded down with a level elevation to get an accurate estimated volume. Thanks for any response.
5 REPLIES 5
jggerth
in reply to: noli1057
lots of work involved in doing it with vanilla.  thats' where a real civil package comes in,  Civil3d  for one option.  Carlson for a less expensive choice that _may_ be easier to get going with.
dgorsman
in reply to: jggerth
And along with the advanced tools comes more complexity.  Unlike AutoCAD, trying to "jump right in" with Civil3D will lead to hair loss, forehead-to-monitor/keyboard contact, and various and sundry other conditions.
If a high level of accuracy isn't needed and there aren't a lot of points it can be done with a few steps in AutoCAD:
- break overall area into logical flat areas
- outline with POLYLINEs and extrude to depth
- get volume with MASSPROP or other methods
noli1057
Thanks! I tried the LOFT command approximately connecting point with line to generate surface but its not looks good. I will ask the PM's for a Civl 3d CAD base. Thanks a lot.
vladimir_michl
You can also try the freeware utility "DTM" to create a basic terrain surface from 3D points. See http://www.cadstudio.cz/dtm
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
braudpat
Hello from France
When I have many XYZ AutoCAD Points and I want to create a DTM, I used (since a long time ago) the "nice good old" Triangulate.vlx routine from Elpanov - THKS to Elpanov !
I have attached it to my msg ... This routine can run (on any ACAD/AA/MEP/MAP/CIVIL/etc x86 or x64) until a maximum of about 800 000 XYZ points !
I hope this routine can help you !?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
