Has anyone delt with an Invisible layer. I had a drawing crash on me and now one of my text layers is invisible in all versions of the drawing; DWG, BAK, Recover and SV$
MTEXT Layer: "historic_markers_MText"
Space: Model space
Invisible
Material: Sitework.Planting.Gravel.Mixed
Handle = 16e0e
Style = "Standard"
Annotative: No
Width: 1498.09
Normal: X= 0.00 Y= 0.00 Z= 1.00
Rotation: 0d0'0"
Text height: 100.00
Line spacing: Multiple (1.000000x = 166.67)
Attachment: BottomRight
Flow direction: ByStyle
Contents: The First Courthouse
I don't know how it got that Material assigned but changing it or setting a shaded ViewStyle doesn't get it to show.
Allen Jessup
Civil 3D / IDSP 2014
Dell Precision T3610, Xeon CPU 3.70 GHz
Win 7 Pro, 64-bit,32 GB RAM, Nvidia Quadro K4000
Samsung SSD 512GB
HGST (WD) 512GB drive
Allen Jessup
CAD Manager - Designer
Solved by rkmcswain. Go to Solution.
"Invisible" I believe, is a property to indicate the object is being hidden via the Isolate feature (ISOLATEOBJECTS / HIDEOBJECTS)
If you can't get it to UNISOLATE, perhaps use MOVE or COPYTOLAYER to put it on another layer.
Also, maybe look into OBJECTISOLATIONMODE.... If it's "1" that may explain why you can't see the objects in your baks and recover files either.
Thanks. I'll try them when I get back to work.
Allen
Allen Jessup
Visible is just an object property like layer or linetype, just not as easily accessible for change.
As mentioned, layer isolate or hide object can do this, and ToolPac has a couple of tools for making objects visible and invisible.
Try the command UNHIDE.
Hi Allen,
I was checking to see if the suggestions provided allowed you to resolve this, or if you still needed assistance?
Allen Jessup
Here is an good example of using autolisp to make objects invisible, and it includes a function that will tell you how many objects are invisible in a given drawing also.
Thank you. That lisp does it. It also proves it was an object property as you said. I had begun to think otherwise because when I used inspect on one of the Mtext. It didn't show an invisible property.I see the Lisp is putting in the Visible property. So that confirms it is by object.
A workaround I had just proved before seeing your post is to Wblock out all the invisible Mtext, open the drawing created by the Wblock where the text is visible, ( I changed the name of the layer because I thought it might be a layer based property), selected all the Mtext and did a copy/paste to the original drawing. The text us visible in the original drawing. I undid that and used the Lisp you linked to and that set the Mtext to visible.
Strangely. I never made that text hidden in the first place. It disappeared after doing a plot. The origin of the text may come in to play. It was originally from a SHP file that was attached using FDO and then saved to a DWG. Also I had tried Hiding all the invisible text and the UnHiding them. That didn't work so.....
Allen
Allen Jessup
The clr lisp works. However every time I save the drawing the text is set back to Invisible and I have to run the lisp again to get it back.
I've attached a drawing containing only the text. If you open it you won't be able to see the text unless you run the lisp. You can list All and see that they're there.
Allen
Samsung SSD 512GB
Allen Jessup
OK. So I'll work this way using the Lisp to see the text until I'm done. Then I'll use my first workaround of Wblocking the text out, erasing it in the original drawing then inserting the Wblocked drawing. The Lisp lets me see what I've done so far!
Just to make it weirder. I just NCopied the first MText of the day and THAT one doesn't turn invisible after a Qsave. All the rest still do!
Allen
Allen Jessup
