Hi-
I'm working in C3D 2014. When I try to use the "invert clip" option in the IMAGECLIP command, it keeps clipping everyting outside the boundary rather than inside. I've tried both tiffs and jpegs. I've tried attaching the image through the xref manager. I've tried dragging the image into the file. I've also tried just using the CLIP command. It works on some of my coworkers' computers, and not on others. Is there a system variable or some obscure setting that would affect this? It did it to me in 2013 also.
Thanks so much!
Meredith
C3D 2014
Windows 7 64 bit
are you trying then with different polylines or did you always use the same geometry/drawing for your tests?
Can you upload the drawing with the polyline you tried? Or can you first look that the polyline is "clean", no crossing segments, no double points as corners, ...?
What service pack have you installed for your C3D 2014?
- alfred -
