Someone please help me. I have read all these threads on this site and beyond and nothing is opening my file.
Heres the info
Using Student Version of AutoCad 2014 on Acer Aspire V3-772G-6468
This message pops up when i attempt to open my file after autocad crashed when importing a block from a website
Error in BLOCK_RECORD Table
Invalid symbol table record name: "" on line 5236.
Invalid or incomplete DXF input -- drawing discarded.
Apparently I saved my file as a 2000 DXF file. So as I was working off a given DWG file, everytime I saved my drawing, It saved as a DXF .
Autocad crashed and now nothing will open my drawing.
I have a deadline !!
Here's what I've done to fix it according to numerous threads on similar issues.
Open in Notepad and find the specfic line corresponding to the error message and fix the problem - DIDNT WORK
Rename the file with a .DWG- Didnt Work
Try opening the file in TrueView - Didnt Work
Recovery, Audit, WBlock. - cant even attempt to do this because as soon as I hit enter or space after writing audit in the command line, it disappeers and becomes the normal Drawing 1 when you start a new drawing. - Didnt Work
Sent the file to other people to try and open - Didnt Work
I have attached the file. please someone help me!
Solved by pendean. Go to Solution.
Hi
When is open .dxf file - it shows Entities not allowed in *MODEL_SPACE block definition on line 134222.
i have dead line to submit the drawing, please see the attached file and help me.
without warranty ...
- alfred -
