Hi, I made a 3D skeleton made in several lines. There were also intersecting lines in it. I would like to break all intersecting lines along each point of intersection, is there any command that I can use?
Please see attached snapshot. you will see some red dots where I would like to break using a single command other than break a point.
Thanks!
Solved by nestly2. Go to Solution.
You can use BREAK with the {F]irst point option if you don't mind breaking everything manually, otherwise I'd suggest BREAKOBJECTS.lsp by Charles Allen Butler (CAB) which as several break tools that will complete your task in one operation (BREAKALL / BREAKSELECTED)
