I have a question about AutoCAD 2015 and the Internet Explorer v9 requirement. Will AutoCAD 2015 refuse to install if IE9 is not installed?
Also - if it will install without IE9, which parts of AutoCAD would not function properly as a result?
Thanks for any advice you can give on this.
Just to clarify, the requirement is IE9 or later.
I don't know for sure, but I suspect the things that rely on IE functionality would be HELP, the activation process, A360 access (login page), and other items in the Infocenter. Hopefully some other replies here will clear it up some more.
