I am building an lab image to install onto 125 systems. My question is how can install autocad without users encountering installing first run and installing language packs. In the olds days of XP I used to run all the autodesk software as administrator and then copy the administrator profile over to the default user profile and that would be all the "first run" taken care off.
Now when I build my image and run the autodesk software and then sysprep (windows 7) the system. Anyone who logs on has to go through the inital startup run. It is very time consuming in a class room enviroment with limited teaching time.
Has anyone any advice on this issue. Sorry for the rambling style of the post.
Kind Regards,
Kevin
My guess is that is to be expected and should happen. Regardless of how the software is installed, whom ever logs in as a different person other than the person who setup the image - the OS and software need to setup stuff within that specific users OS profile in order for everything to work as expected.
You might have better luck over in the Installation & Licensing forum;
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
HTH
With this I start up 9 seconds faster.
space/nologo after file extention name.
Thanks for the replies, I will check in the Installation & Licensing forum.
Kevin
