AutoCAD Forum
Installing AutoCAD 2015
2 REPLIES 2
btucker
292 Views, 2 Replies
Running Windows 7 pro 64 bit and trying to install AutoCAD 2015 64 bit from flash drive and I get a pop up asking to install AutoCAD Disk 1.  This pops up trying to install on stand alone and while creating deployment.  Anyone know of a fix or a reason?
Thank you
2 REPLIES 2
pendean
in reply to: btucker
where did the contents of the flashdrive come from?
Are you trying to run the setup.exe file? Open the folder /setup/x86/acad
and run acad.msi instead.
btucker
in reply to: pendean
Thanks for the reply.  The contents are from the download section here.  I will try your recommendation.
”Boost
