AutoCAD 2013/2014/2015
Distinguished Contributor
GegH1
Message 1 of 4 (3,179 Views)
Install error AutoCAD 2013
3179 Views, 3 Replies
10-04-2012 01:56 PM
I get an installation error when installing 2013.
AutoCAD installs fine but it is the inventor component that hass an error.
I believe this is due to me having a newer version of Microsoft Visual C++, i require this for other software.
Does anyone have any suggestions, it wouldn't normally bother me but i get an annoying message telling me that AutoCAD hasn't been installed properly every time i start up.
The error is below:
2012/10/5:09:35:39 Geg GEG-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): D:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Geg\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/10/5:09:35:46 Geg GEG-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
Creative Intentions
Win 7 Pro 64bit, Dell Precision M6500
I had a similar problem some time ago when Windows-update had updated the C++XXXX redistributable to a newer version than DesignReview (as part of the AutoCAD-installation) tried to install.
The solution was to uninstall the C++xxxx redistributables (including updates if there are any) and then start the installation again.
Good luck, - alfred -
Alfred.NESWADBA
Message 2 of 4 (3,156 Views)
Re: Install error AutoCAD 2013
10-05-2012 10:57 PM in reply to: GegH1
Alfred NESWADBA
GegH1
Message 3 of 4 (3,148 Views)
10-06-2012 01:32 AM in reply to: Alfred.NESWADBA
The problem is i need c++ because i am building an application with visual studio.
Creative Intentions
Alfred.NESWADBA
Message 4 of 4 (3,139 Views)
10-06-2012 04:06 AM in reply to: GegH1
You should just uninstall the redistributable! And when AutoCAD installed then successfully you can reinstall it again (if it's not already installed then by AutoCAD).
- alfred -
Alfred NESWADBA
