How in Autocad 2014 do you place 3D text embossed on to a cylinder circumferance?
Wrap around a curve surface is not available with autocad (Inventor can do it)
Autocad can do Extrude, Imprint, Project geometry......
Not quite the same as using Emboss - Wrap to Face in Autodesk Inventor, but the attached file might give you some ideas.
I guess you figured out solidedit imprint and solidedit color faces.
