AutoCAD Forum
In Autocad 2014, 3D embossed text on a solid cylinder circumferance
5 REPLIES 5
alex
2440 Views, 5 Replies
How in Autocad 2014 do you place 3D text embossed on to a cylinder circumferance?
5 REPLIES 5
Patchy
in reply to: alex
Wrap around a curve surface is not available with autocad (Inventor can do it)
Autocad can do Extrude, Imprint, Project geometry......
JDMather
in reply to: alex
Not quite the same as using Emboss - Wrap to Face in Autodesk Inventor, but the attached file might give you some ideas.
alex
in reply to: alex
thank you.
alex
in reply to: JDMather
thank you , very helpful indeed.
JDMather
in reply to: alex
I guess you figured out solidedit imprint and solidedit color faces.
”Boost
