RECEIVED A SOLIDWORKS FILES, TRYING TO BRING OVER TO AUTOCAD,
RUNNING ACAD2013 WITH INVENTOR FUSION 2013,
DO I HAVE THE TOOLS TO IMPORT THIS FILE?
I don't think you have to tools to do it unless you have a license of Solidworks. I do have a license of Solidworks 2010 Premium which should allow me to do it no problem. The trick is the user with Solidworks must export the drawing to a .dwg format from inside Solidworks. Post the file and I'll do it for you when i get home from work!
Tom
THERE IS AN OPTION TO IMPORT, BUT I THINK THEIR FILE MIGHT BE A VERSION BEYOND MINE.
I do not see any part files (*.sldprt) in the folder, only the assembly file (*.sldasm).
An assembly file is simply a record of hyperlinks to the parts and instructions on how to assemble them and a bit more (think xref).
The source should have given you the parts - apparently they don't know how to use SolidWorks.
Most of the other information in this thread is also incorrect.
AutoCAD 2013 will read SolidWorks 2012 files.
SolidWorks 2014 did not exist when AutoCAD 2014 was released - so AutoCAD 2014 will only read up to SolidWorks 2013.
You can only open SolidWorks assembly and part files, not native drawing files. SolidWorks can write out several other formats to go between different CAD programs.
As noted by others, this file is mising its External References (related PRT and ASM files).
When receiving SolidWorks Files, ensure that you receive all the necessary files. PRTs, ASMs etc.
The best way to receive all is to request a "Pack and Go" with all the options selected.
If it is necessary to import the solids only, as a placeholder or space saver, request a file type that AutoCAD can import readily. The format I have had most compatibility and least errors with is ACIS SAT.
!!Ensure that version 7.0 or below is also specified for the export as AutoDesk cannot import versions higher than this as they do not support later version for whatever reasons I wil lnto go into here.
This "simple" exchange format is useful when supliers cite "Proprietary Information" as reason not to supply 3D models because only the external parts, or surface geometry are exported, i.e. the "shell of the item.
There is no "free" SolidWorks viewer that will open native format files and save out to other formats.
NavisWorks Manage can import older versions of SolidWorks files, as can Inventor.
AutoCAD 2014 also should be able to import this file, however it cannot process the file, most likely because of the missing references.
For your Information:
Parts (SLDPRT) and Assemblies (SLDASM) NOT supplied is listed below.
S_KS_36131100_-MOLD_M1XLLS_F_8LOBES_0800NH_COPY.SLDASM
36130212_-Tight_Nut_TR114x4_octa.SLDPRT [Not Found] File Not Found
36613606_-Extruder_Coupling_with_Conic_2.SLDPRT [Not Found] File Not Found
36613609_-Ring_f_locking_Conic_hole_0675NH.SLDPRT [Not Found] File Not Found
36129612_-Conic_plug_0675NH.SLDPRT [Not Found] File Not Found
36130225_-Assy_Disassembly_upper_TR_0800NH.SLDASM [Not Found] File Not Found
36613614_-Plug_f_locking_Conic_hole_0675NH.SLDPRT [Not Found] File Not Found
36920154_-SCREW DIN912-M16x25-10_9.SLDPRT [Not Found] File Not Found
36131108_-conic_plug_f_core_ring_8lobes.SLDPRT [Not Found] File Not Found
39040007_-NIPPLE_G1_4_Brass.SLDPRT [Not Found] File Not Found
36920192_-GROUTING_LANCE_F_CORE_HEATING_NH.SLDPRT [Not Found] File Not Found
36920194_-BUSH_F_GROUTING_LANCE_F_CORE_HEATING_NH.SLDPRT [Not Found] File Not Found
36455100_-ADAPTER_F_CORE_HEATING_NH.SLDPRT [Not Found] File Not Found
36455102_-ADAPTER_F_ROTARY_FEEDTHROUGH_NH.SLDPRT [Not Found] File Not Found
36920193_-ROTARY_FEEDTHROUGH_F_CORE_HEATING_NH.SLDPRT [Not Found] File Not Found
36455101_-SPANNER_F_ADAPTER_F_CORE_HEATING_NH.SLDPRT [Not Found] File Not Found
10315494.sldprt [Not Found] File Not Found
36130205_-PROFILE_STOP_0800NH.SLDPRT [Not Found] File Not Found
36130207_-Distance_Sleeve_Upper_0800NH.SLDPRT [Not Found] File Not Found
36130230_-LOCKING_TUBE_0800NH.SLDPRT [Not Found] File Not Found
36130204_-CORE_ADAPTER_0800NH.SLDPRT [Not Found] File Not Found
36130211_-Tight_Nut_TR100x4.SLDPRT [Not Found] File Not Found
36130210_-Tight_Nut_M160x6_wide_60mm.SLDPRT [Not Found] File Not Found
36130221_-fluid_adapter_0800NH.SLDPRT [Not Found] File Not Found
36126916_-WATER_CAP_800_CDP-HDI.SLDPRT [Not Found] File Not Found
36614500_-DISASSY_DEVICE_CPL_6_lobes_0800NH.SLDASM [Not Found] File Not Found
36130209_-DISTANCE_RING_0800NH.SLDPRT [Not Found] File Not Found
36920127_-SQUARE_RING_164X148X8.SLDPRT [Not Found] File Not Found
36613703_-adapter_f_core_roller_TR100_0800NH.SLDPRT [Not Found] File Not Found
36115326_-CORE_ROLLER_ASSY_0800NDS.SLDASM [Not Found] File Not Found
36920196_-AXIAL_BEARING_OD170mm_0800NH.SLDASM [Not Found] File Not Found
10280717_-STOP_RING_F_STATOR_Sys_G_0800NDS.SLDPRT [Not Found] File Not Found
36920153_-SCREW DIN912-M24x200-8_8.SLDPRT [Not Found] File Not Found
36097400_-STATOR_CORE_M1XLLS_0800NH.SLDPRT [Not Found] File Not Found
36131106_-Core_Ring_f_8lobes_0800NH.SLDPRT [Not Found] File Not Found
36131103_-ASSEMBLY_DEVICE_M1XLLS_0800NH.SLDPRT [Not Found] File Not Found
N900001181_-LIFTING-EYE-BOLT-DIN580-M24.SLDPRT [Not Found] File Not Found
