AutoCAD 2013/2014/2015
Valued Mentor
SeanFarr
Message 1 of 6 (2,559 Views)
Accepted Solution
Import Title Block to AutoCAD 2013 from Inventor 2013
2559 Views, 5 Replies
03-12-2013 11:30 AM
I am very new to AutoCAD and am wondering how to fix my title block. I use Inventor 2013 regularly and only sometimes require the use of AutoCAD, mainly for 2D electrical layout drawings.
I have saved my drawing .idw template file from Inventor to a .dwg
Inserted it into AutoCAD .dwg
Saved as an AutoCAD .dwt
now the only issue that I have, is the image that I had embedded into the inventor drawing template, shows up as an icon instead of my compnay logo:
Is AutoCAD capable of showing images in a title block and hwo would I go about deleting the current icon image and replace it with the logo?
I tried deleting the current image in block editor but it won't let me select it.
Thanks!!!
Sean
AutoDesk Product Design Suite 2013
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
You may be able to open your logo file in photo editing application and perform a copy and paste into Autocad resulting in an OLE object.  Does that work for you?
Valued Mentor
SeanFarr
Message 2 of 6 (2,548 Views)
Re: Import Title Block to AutoCAD 2013 from Inventor 2013
03-12-2013 12:04 PM in reply to: SeanFarr
So I edited my inventor drawing template, exported as a dwg, imported into AutoCAD as a .dwt and ended up with this:
I got rid of the icon logo issue, but now I just need to insert my compnay logo, any help would be appreicated.
Sean
Sean Farr
Distinguished Mentor
tschau3
Message 3 of 6 (2,539 Views)
03-12-2013 01:42 PM in reply to: SeanFarr
*Expert Elite*
JGerth
Message 4 of 6 (2,533 Views)
03-12-2013 02:37 PM in reply to: tschau3
While OLE is a possible option, there are other issues with OLE, and final output quality generally leaves much to be desired.
Best advice iI can offer is to recreate your company logo with native AutoCAD entities.  That will give you the most flexibility and highest quality.   Since it's the company logo you're talking about, a brand identity that your customers see - you don't really want them to associate that with blurry, low quality images.  Sends a poorer message than I would want to communicate.
Valued Mentor
SeanFarr
Message 5 of 6 (2,509 Views)
03-13-2013 06:14 AM in reply to: tschau3
This will work, I created a simple logo awhile back, and it looks fine, copy and paste worked from MS Paint.
Thanks!!
Sean
Sean Farr
Valued Mentor
SeanFarr
Message 6 of 6 (2,507 Views)
03-13-2013 06:16 AM in reply to: JGerth
Thanks for the heads up in regards to the OLE issues that may be ahead, for now though becasue of time constraints, I will use an image, and will look into logo re-creation in AutoCAD.
Thanks!!
Sean
Sean Farr
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
