When I try to import any .step (AP203 or AP214) files from SolidWorks 2014 into AutoCAD 2014, the "import job in progress" doesn't seem to do anything. When I hover over it, nothing shows up. I've tried to right-click to bring the imported part in and it just seems like that buttom is locked. Any ideas? Running Windows 8.1 64 bit.
I think you have to look a the lower right corner of your autocad screen until it's done and follow the prompt.
Patchy, I waited for quite some time thinking that might be the issue and no notification came up. It's just very odd that when i over over the button in the lower right hand side or right click on it, nothing happens at all. It just seems locked. Could that be the issue?
Thanks, I'll look into that and let you know if that fixes it. I should have also stated that my co-worker is running all the same software, except he's on Windows 7 and he is able to convert parts with no issue.
