hi,
Anymore can give me any ideas or suggestion on how to import the list (the tabulation is attached in the Example.dwg) and generate accordingly shown dwg file attached (Example.dwg). Any good programming scripts can be sharing here and any recommend excel formula can be used? Manually adjust the curve and input the numbers one by one might take plenty time and more time spending to checking.
Note* (-) minus convex curve
(+) plus groove curve
Not really sure what you're wanting to do, but you may want to look into the following:
Data Extraction.
AutoCAD Tables
Data Connect (to Excel files)
Using Fields to report entity data.
For a one time survey this isn't worth the effort, if this is something you do regularly, then the question is, is it always the same layout.
I would start by creating an excel sheet and filling in all the different points of a standard tank and then use a column to the side to enter the survey data and a third column to show the difference, I would imagine you have this already (maybe not the standard coordinates). Do you have an excel sheet ready prepared that you could attach, and is the attached drawing a template that you always use for these tanks? Then it is just a question of laying out a few cells to include the autocad commands for drawing the lines and copying and pasting this into autocad, it should take only seconds for the drawing to be created once the data is input into the excel sheet. But I must stress it's only if this is standard procedure, if you use different size tanks it would need doing for each size.
