AutoCAD Forum
Ignore xref with match properties
13 REPLIES 13
Message 1 of 14
jcole
3505 Views, 13 Replies
Is there a way to get the match properties command to ignore external references? When I use the match properties command (A LOT!) I have to try to not hover over the xref becuase it hightlights and locks up my cursor for a few seconds...I setthe ERHIGHLIGHT to 0 but it is still highlighting..
thanks
13 REPLIES 13
Message 2 of 14
massimo.corradi
in reply to: jcole
Yes! Go to >Options >Selection >Preview >Visual Effect Settings. There in >Advanced Options you can set Xref (and other stuff) to be excluded from highlighting when you mouse over them.
Message 3 of 14
jcole
in reply to: massimo.corradi
I tried that also. It is still picking up the xref when I use match properties. It may not be completely highlighting it but there is a noticable hesitation when I hover over the xref.
Message 4 of 14
zalant
in reply to: jcole
For the MATCHPROP command, there are two phases:  first you select the source object, and then you pick the target object. The 'Exclude' checkbox items that Massimo made reference to only affect the selection of the source phase of MATCHPROP. The xrefs will still be considered by Selection Preview during the phase of picking the target object. This behavior is as designed.
You might consider putting your xrefs on a specific drawing layer, and then toggling that layer off prior to executing the MATCHPROP command.
Zac Travis
Message 5 of 14
m177
in reply to: zalant
My 2013 version doesn't do this, but my 2016 does highlight.  It's very annoying and inefficient.
When did this "feature" become part of AutoCAD?
Message 6 of 14
m177
in reply to: m177
Ok.... so at least for AutoCAD 2016 (I think this applies to 2015 as well), COMMANDPREVIEW system variable is the cause for this issue.
It is ON by default and tries to show you what the outcome will be if you do what you are intending on doing, i.e.  match properties of a dash line to a solid line will let you preview what the solid line would appear like if you do select.  I'm sure there is a good use for this feature, but it slows down my computer too much.
Message 7 of 14
jason.lowZL7M6
in reply to: m177
Thank you so much M177 - You have reduced my assisted in reducing my AutoCAD stress level.
Message 8 of 14
Hi @jason.lowZL7M6,
CommandPreview can be useful at times but toggling it off is easy too.  You might also explore using the SelectionPreview command as well to see how it might affect your process.
John Vellek
Message 9 of 14
j.t.c.low
in reply to: john.vellek
Hi John, thank you for that. I have adjusted the selectionpreview variable before and it works wonders.
kind regard,
Jason
Message 10 of 14
faisaljaveduae
in reply to: jcole
 go to option-selection-selection mode and then unchek Non/Verb selection
this can solve your prob
Message 11 of 14
willsrancho
in reply to: jcole
Go to options >Selection > Uncheck Command preview under preview section. problem solved. Enjoy!!!
Josh
Message 12 of 14
faisaljaveduae
in reply to: jcole
Thanx bro
Message 13 of 14
Carlomight
in reply to: jcole
I know this was marked as Solved a long time ago already, but I humbly think the solution wasn't satisfactory. I personally dont like renouncing to the command preview, so what I do is far simpler: I have my xrefs on a layer which I then lock. Just that...
Message 14 of 14
RobDraw
in reply to: Carlomight
Or the question wasn't worded well.
Rob
”Boost
