is it possible to turn of the grid in a layout top view? it odes not show in a side view.
and how can I show the grid when in a side view in model space? I only see it on the floor?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Claas Kuhnen
That sounds right. The grid is intended for the X Y directions. So to get it in a ‘side’ view or elevation view, either the UCS needs to get reoriented or the model/elements need to get reoriented. If it’s just for one view, perhaps 'cheating' it would be a good approach –by copying and then rotating the model/geometry so you have the grid background without adjusting the UCS.
Or perhaps you could set the grid to follow a dynamic UCS (DSETTINGS) Then set the GRIDDISPLAY variable to 8. Then use a dynamic UCS. (Not sure if that would be closer to what you want?)
P.S. Thank you for your contributions as an Expert Elite! That’s an awesome program. Kudos!
(If my reply post was helpful, please give a "Kudos" or mark the "Accept as Solution" button below -or both).
