OK, I am sure this is an easy one, but how do I turn off or minimize the number of icons that show up along the bottom of my Acad screen? There are so many, that the layouts of my drawing have to be selected by using a drop down. See attached for example.
Thank
KW
Solved by Light_Guy. Go to Solution.
Solved by nestly2. Go to Solution.
In AutoCAD2014 and earlier, right click on any of the icons and select "Display" from the right click menu and uncheck those you don't want displayed.
In AutoCAD2015, click the icon in that status bar that's the fartherest to the right... (3 horizontal bars) and remove the checkmarks from those you don't want displayed
If you are using 2015, click on the Customization icon (furthest to the right) and a pop up menu will appear where you check on/off each icon. For 2014 and earlier, you can right click in an open space on the bar and you will get a pop up menu for OSNAPS, POLAR, etc and then for the right side icons (Paper/Model, Hardware acceleration, etc..) there is a small pull down arrow between Isolate Objects and Clean Screen that will give you the pop up menu.
Also, you can move the tabs/layouts above the Status bar (if you don't mind giving up the screen real estate.
Right click on any Layout tab > Dock above Status Bar
