I am looking for a 10 cubic foot Blender. This item will be used to illustrate how much room is needed to install one or if necessary, how much room it will take inside a Pharm. process room. We also need it to insure the connections are going to be in the right place.
I have seen 3D models before, that looked great and would help my Principals see better.
Can anyone help? Even a PDF with dimensions would be helpful at this point.
HD
Solved by JDMather. Go to Solution.
Does the manufacturer have a website with CAD models?
Have you checked GrabCAD?
You did not supply any manufacturer or model numbers - but I found some hits using the term "mixer".
You are right, I enter mixer and found the blender I needed.
Thank you very much.
HD
