AutoCAD Forum
I cannot specify rectangle size or line length after an error
2 REPLIES 2
hawaiipanama
1742 Views, 2 Replies
I cannot specify rectangle size after an error shutdown my AUTOCAD LT 2015. I had been drawing rectangles for about two hours without an issue. I use the ribbon to choose rectangle and click for p1, type in the desired size then tab to p2 and type in that size. Everything was working fine until AUTOCAD had an error and shutdown. I did not copy the error number because I did not think anything of it. MS does it all the time and we just restart the PC. Now I can't specify the size. I can't specify a line length either. Anyone experience this? Do I need to reset something?
Mahalo in advance.
Aloha,
Brian
2 REPLIES 2
ampster402
in reply to: hawaiipanama
not sure if LT has this, by try disabling DYN Mode (Dynamic Input)
You may have better luck over in the LT forum;
http://forums.autodesk.com/t5/AutoCAD-LT-General-Discussion/bd-p/43
hawaiipanama
in reply to: ampster402
I will take a look. Sorry about posing this in the wrong area. First time user. I will move it over to LT.
Mahalo,
Brian
”Boost
