AutoCAD Forum
I cannot download AutoCAD 2015 because of "Network Error" issue
5 REPLIES 5
mericsuna
4804 Views, 5 Replies
  Hello. I am trying to download AutoCAD 2015 via my Student License to Windows 8.1 x64 but, I take the problem which I will put its screenshot now. Would you mind if you help me to fix this? Thanks in advance.
5 REPLIES 5
GPSJane
in reply to: mericsuna
Slow connection? If the download loses connectivity for a certain period of time it would time out. Have you tried emailing them? They tend to respond and sort stuff out quite well.,
DarrenP
in reply to: GPSJane
try downloading from here
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links
Please accept as a solution if this fully resolves the issue
DarrenP
mericsuna
Yes, you are right about my connection speed. It is 1 megabit. But, I don't think it has been caused by slow connection. If it is caused by slow conection, why it was stopped at middle, not at beginning? Why it hasn't been solved though I had pushed "Retry" button over and over again? Thank you very much.
GPSJane
A slow connection can be steady and work for a while then time out anyway because a delay just took too long. The retry might be starting from scratch, not from where it failed.
Try the download site mentioned above.
mericsuna
Ma'am, do you know if there is an offical one-link download of AutoCAD 2015?
”Boost
