AutoCAD Forum
I can't select a construction line.
2 REPLIES 2
TCWestern
8592 Views, 2 Replies
I created a construction line on layer zero. Then I rotated it 30 degrees. Now I want to delete the line, but I can't even select it. I checked if the layer was frozen or off. What's the deal? I will attach the file. (The drawing was created using AutoCAD Electrical, but I don't think that is where the problem is.)
2 REPLIES 2
TCWestern
in reply to: TCWestern
Never mind. The construction line was inside a block; even though that doesn't explain why when I selected the line, the whole block didn't get selected. How did the construction line get in my block:)?
Kent1Cooper
I would have to assume via REFEDIT/BEDIT, however accidentally, unless you accidentally selected it in defining the Block.
But in any case, I did find, accidentally in connection with something else, a while back, that when an Xline is part of a Block insertion, you can select the Block on the Xline roughly within the extents of the other Block ingredients, and to some who-knows-how-much-of-a small distance beyond that area, but for some reason you can't select on the Xline farther outside the rest of the Block.  I'd love to know why that is [not that it's something that I ever need to do, since I don't normally have Xlines in Blocks, either].
Kent Cooper, AIA
”Boost
