Hello.
I have 1 problem...
about AutoCAD 2015
1. I made table.
2. I insert text in table text box
At this time, I saw table text box...
It's very big size....
I want to reduce the size.
But I could not find a way.
Please help me.
Solved by Ajilal.Vijayan. Go to Solution.
First try to set the text height for the table cell by selecting the cell and right click and properties.
If that didnt help, try to turn off the below setting in the text editor.
Right click inside the text edit box and turn off 'Always Display as WSIWYG
You may need to revert this setting for mtext edit at later stage.
