AutoCAD Forum
Howto: Making a solid out of/Edit a minserted geometry
7 REPLIES 7
Message 1 of 8
432 Views, 7 Replies
i would like to use 3d dwg files from the 50 wood joint library for cnc processing. Therefore i load a dwg file (like attached) into account and want to start editing the wireframe, but thats not possible. Furthermore I expected to be capable of producing a solid for further processing in a CAM software.
How can I edit and make the attached geometry a solid?
Best regards
c_d
Tags (3)
7 REPLIES 7
Message 2 of 8
Patchy
Old trick of Minsert.
Trace over them or dig the net for a code to get rid of it in .DXF
Join the lines and EXTRUDE, cut out the slots where they occur then STLOUT.
Message 3 of 8
in reply to: Patchy
I tried to find informations to automatically trace my dxf library without sucess used keywords where "(delete) minsert trace dxf".
Since iam a autocad novice: What would be the appropiate way to find a script which removes this minsert restriction?
Message 4 of 8
rkmcswain
It's not so much the MINSERT, as it is the fact that it's an anonymous block because anything that is MINSERTed, can simply be INSERTed (and exploded) **except** for an anonymous block.
But you can convert the anonymous block to a normal block using code here in post 8, then insert and explode as normal ----- I tried it, it works.
Message 5 of 8
Patchy
Autocad novice, how about Microstation?
Microstation would drop these blocks with a click.
Message 6 of 8
in reply to: Patchy
@Patchy it seems a little bit like to far to get a software like microstation to get some editable data - but i got a trial what would the process be like to explode the date? @rkmcswain I tried the from you described way and would had expected that this script after naming and executing it would made joint editable. I tried to drag and drop the script into my canvas and also renamed it according to suggestion of Autocad (see below), But after loading the attached script I get the following feedback: Enter script file name : After pressing Enter nothing happens and the block isn't changed. Are they other ways to make the editable without redrawing this library? Best regards
Message 7 of 8
Patchy
There is a way to open .dxf with wordpad and delete the line code and it would get rid of the *block that minseted but I forgot which line.
Nowaday I just open .dxf with microstation, select the elements with power selector, click on drop element (do it 2 or 3 times make sure it isn't minserted many times as the example you posted) and save it as .dwg.
If you get stuck, post the .dxf and let me see.
Message 8 of 8
rkmcswain
See attached.
”Boost
