I am having dynamic block (point) with arrtibutes x(cordinate),y(cordnate),Z(elevation).
After imoprting points I have shifted the points. How to apdate the x,y (data) attributes.
Solved by dbroad. Go to Solution.
If the block definition has attributes that have block placeholder fields AND if those attributes have not been converted to text AND if those blocks do not have the attribute definitions in a nested block, then the fields(attributes) should update at a regen. This is dependent on your fieldupdate settings. BTW, this kind of behavior does not require dynamic blocks. Post the block if a regen does not work.
Sanjay Mache,
Be sure to sign in before you reply. Second, be sure to hit the reply button below the post you are replying to. The block(BLKATT) in the drawing you posted is not dynamic and so just moving the block will not update the northing and easting. Instead, you should create a new block definition or edit the existing one. If you edit the existing one, make the attributes for northing and easting preset so that they do not prompt for values. In the default value field, right click and choose "insert field...". Then choose block placeholder. Then select "Position". Then leave only the x or y coordinate that pertains to northing or easting.
After you add the fields to the attributes, the position will be updated automatically after each regen. Otherwise, you need to write a program to update the attributes, which is more trouble and less reliable. Adding fields does not make the block dynamic but it will do what you want and will seem dynamic.
dboard,
I thought this was my problem but it didn't work. I have this dynami block that shows it attributes, after ATTSYNC-Name-* they all work fine and after REGEN they update. However when I insert a new one it only shows the tag and regen doesn't work for it. SO i had to run ATTSYNC every time I insert a new block. I have preset and verify activated for those attributes. Any advice?
Thanks a lot!
Post a drawing containing a block reference and explain the problem in the drawing.
Hi All,
It appears it's not only me who struggles with dynamic blocks or attributes.
I originally thought it would take me 5 minutes but I just can't work out what is wrong with my block. The coordinates just won't update!
I have watched a few video tutorials to make sure I am doing it right. I have read other posts, tutorials, comments. I have downloaded several instances of similar blocks which work. And I still have no clue why mine isn't.
I know that it can be used with anything that has a position property, e.g. circle, point or just the block placeholder. Let's assume that I want to go with a point.
I am attaching my instance for review and comments. If I can get a clue what's wrong, it would help a lot.
The idea is that eventually I will add the dynamic features like stretch and mirror to the block, but I can't get through the attribute issue to go further.
your field shows the coordinate of the point within the blockdefinition ... and the point within the blockdefinition is placed at 0,0
To change that you might edit the field and change the object to your block-insertion, then (after REGEN) the coordinate will show the block insertion point.
- alfred -
