AutoCAD Forum
How to smoothly connect 2 circles with arc R 5.00
2 REPLIES 2
jdlobb
3897 Views, 2 Replies
I'm having trouble with this and I can't get ahold of my professor to clarify.  The diagram I"m trying to copy shows a sort of "shoulder" between two circles with Radius .87 and .38.  The diagram specifies that the curve of the line connecting them is R 5.00.
Whenever I try to use a fillet it curves the wrong direction, in as opposed to out.
When I try to use an arc connect at tangents the connection isn't smooth once the curve is applied, it doesn't blend into the circles.
2 REPLIES 2
TheCADWhisperer
in reply to: jdlobb
Draw a Circle using TTR option and then trim the circle.
jdlobb
in reply to: TheCADWhisperer
Eureka!  thank you!
”Boost
