I have a simple question:
How i can scale along one axis in AutoCAD 2015? In earlier version i was transforming objects into blocks and everything worked. In 2015 version this method didnt worked.
Solved by Kent1Cooper. Go to Solution.
Solved by beyoungjr. Go to Solution.
Several other CADD-CAM platforms have routines to do this but AutoCAD never really decided we had a need for that command.
Alas a solution...
I checked to see if there was something I didn't remember and Bob_Zurunkle "Expert Elite" had a previous reponse to this same question in 2011.
As I do more often than should be necessary [second time in just minutes], I will ask: What does it mean that it "didn't work" in 2015? What steps do you take, and what results do you get, and how do they differ from what you want to happen? And is there any kind of message?
@beyoungjr wrote:
- Create a new BLOCK ....
- Delete the original instance of your object that is now a BLOCK.
- Insert the new BLOCK and specify the scale change for the desired axis.
That's more work than you really need to do. Create the Block, and just change one of its scale factors in Properties.
Yeah, and the quickest way to create a block is to select the objects and right-click drag them. When you release the right button, you'll get a menu with the option to paste as block. Explode or redefine as needed after you've scaled it with the properties palette.
Sorry to have explained in my long steps through the Create Block process.
It's the educator in me that hopes to share a solution that any seeker can use (especially newbies). It's the Pro's that can share the tricks and shortcuts and have long left the rudiments behind.
Lots of folks look for the shortcuts or tricks but some are still learning ACAD.
