If you want to remove the $0$ from bunch of bound drawings then try with BatchInEditor or BatchInDatabase, free batch tools available to download from Autodesk Exchange Apps
Add the command "Rename-Objects" to all the bound files which needs to be cleaned and run the batch to clean the $0$.
You can also just RENAME and select all the layers *$*$* and replace with *
