AutoCAD Forum
How to remove the dollar symbols in bainded x ref layers?
4 REPLIES 4
dilsmails1
1106 Views, 4 Replies
Hay all Anybody have an idea of how to remove the dollar symbols in bainded x ref layers?
Dileep
4 REPLIES 4
3wood
in reply to: dilsmails1
I think you need a routine to do the job.
You can try LQM command in LAYER.vlx
abubakars
If  you want to remove the $0$ from bunch of bound drawings then try with BatchInEditor or BatchInDatabase, free batch tools available to download from Autodesk Exchange Apps
Add the command "Rename-Objects" to all the bound files which needs to be cleaned and run the batch to clean the $0$.
tedwardspg
in reply to: 3wood
You can also just RENAME and select all the layers *$*$* and replace with *
ACA 2013
Windows 7 enterprise
Intel core i7 860 @ 2.80GHz
16GB RAM
NVIDIA Quadro FX 1800 - 4GB
dilsmails1
in reply to: tedwardspg
How to RENAME *$*$* and replace from the layer list where is that option? could you please help
Dileep
”Boost
