I am using LT 2013. I cannot figure out how to match properties for text. I click on the 2 options and the box witdth, orientation, layer will match but not the style or font. I have tried using Quick Properties to select but have not had any success with this tool. Here is what I did:
Created a style and named it Arial.
Open the Quickselect box.
Apply to : click the box and select the various mtext objects.
Object Type: mText
Properties: Style
Operator: Select All
Include in New Selection Set is checked.
I click Ok and the objects are selected.
Next I go to the Properties Manager and change the style to the one I want to use, bu the text does not change. If Idoubleclick a text object it shows the correct style, but not the correct font. What have I missed doing?
Solved by pendean. Go to Solution.
Match Prop will change the object size, rotation, layer, everything except the font. It says it is the correct Style, but the font does not change. Is this a glitch? Any other object you choose Match Prop will change everything, just in m Text it will not change the font. I even tried changing the font in the Style and it did not make a diffence.
OK, figured out the right click. Select the text object, in the text editor select the text, right click and in the popup menu select 'Remove Formatting>All Formatting." Then you can use Match Properties, but again, it has to be done to each text object individually.
That clears up one mystery, thanks. I will accept this as the solution.
Oops too soon. It worked once, but I can not get it to do it again.
