AutoCAD Forum
how to make current color in Color Contro the same as the color of an object
7 REPLIES 7
Message 1 of 8
RChalmers2
1233 Views, 7 Replies
Is there a way to click on an object and have it's color be the current color in the Color Control dropdown?  Or some similar way to change the color control?
7 REPLIES 7
Message 2 of 8
hgasty1001
in reply to: RChalmers2
You need a little help from Autolisp to do it:
(defun c:setcecolor (/ cecolor ent)
  (setq ent (car(entsel)))
  (if ent
    (if (setq cecolor (cdr (assoc 62 (entget ent))))
     (setvar "CECOLOR" (itoa cecolor))
     (alert "The selected entity has color set to Bylayer")
Gaston Nunez
Message 3 of 8
3wood
Something like this one?
(defun C:SetColorByObject (/ color colormethod bookname)
  ;;; SetColorByObject.lsp By 3wood (2014.11.12)
  (vl-load-com)
  (prompt "\nPick up an object to set current color:")
  (setq color (vla-get-truecolor (vlax-ename->vla-object(car(entsel))))
	colormethod (vla-get-colormethod color)
	bookname (vla-get-bookname color)
  (cond
    ((= colormethod 192) (setvar "cecolor" "BYLAYER"))
    ((= colormethod 193) (setvar "cecolor" "BYBLOCK"))
    ((= colormethod 195) (setvar "cecolor" (itoa (vla-get-colorindex color))))
    ((and (= colormethod 194)(= bookname ""))
     (setvar "cecolor" (strcat "RGB:"
			       (itoa (vla-get-red color)) ","
			       (itoa (vla-get-green color)) ","
			       (itoa (vla-get-blue color))
    ((= colormethod 194)(setvar "cecolor" (strcat bookname "$" (vla-get-colorname color))))
  (princ)
Message 4 of 8
Kent1Cooper
Here's a way that gets around the fact that there's no (assoc 62) entry in entity data for objects whose color is ByLayer:
(setvar 'cecolor (itoa (vla-get-color (vlax-ename->vla-object (car (entsel "\nSelect object to set its color current: "))))))
[It does require (vl-load-com) first if that hasn't already been done.]
Kent Cooper, AIA
Message 5 of 8
RChalmers2
in reply to: hgasty1001
Works! Thanks.
Message 6 of 8
RChalmers2
in reply to: 3wood
What is the command?
Message 7 of 8
RChalmers2
in reply to: Kent1Cooper
I'm not a coder. Can you explain this?
Message 8 of 8
RChalmers2
in reply to: 3wood
I figured out the command. Works great! Thanks
”Boost
