i have a big problem in rotating dimension text,, i rotated the dimension but my dimension text doesnt rotate. i have an attached image here in file name called CAPTURE, thats what i want,,, in file name CAPTURE2 thats my problem. any help??? tnx
Solved by 3wood. Go to Solution.
I don't work in manufactory field and the solution below may not be the best. But you can use it to do the task for time being.
hey sir, thanks, it helps me a lot... welll before i can do that but because i didn't use this everyday i forgot it. thanks a lot again.
