AutoCAD 2013/2014/2015
New Member
m.agert
Message 1 of 6 (25,228 Views)
How to install Autodesk Autocad 2013 x64 or x86 on Windows 8 Consumer Preview?
25228 Views, 5 Replies
04-03-2012 05:25 AM
The Autocad 2013 x86 or x64 is not installed on Windows 8 Consumer Preview
because programs can not read .NET Framework versions 2 and 4 which are integral parts of the OS. How do you solve this problem?
rkmcswain
Message 2 of 6 (25,227 Views)
Re: How to install Autodesk Autocad 2013 x64 or x86 on Windows 8 Consumer Previe
04-03-2012 05:41 AM in reply to: m.agert
Windows 8 is not a supported O/S
pendean
Message 3 of 6 (25,224 Views)
04-03-2012 05:45 AM in reply to: m.agert
Long thread with good information:
http://forums.autodesk.com/t5/CAD-Managers/Anyone-try-Windows-8-Developer-preview/td-p/3349977
Basically, since Win8 aleady has .NET4 you need to manually edit the installer to not try and install it.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
sarim_xyz
Message 4 of 6 (24,324 Views)
05-30-2012 12:04 AM in reply to: pendean
installation of autocad 2013 worked fine by editing the .ini file, but it crashes with unhandled access violation error!! :smileysad:
check this out:
http://forums.autodesk.com/t5/AutoCAD-Mechanical/AutoCAD-and-Windows-8-Consumer-Preview/m-p/3430011
New Member
martin_cull
Message 5 of 6 (18,564 Views)
11-20-2012 01:22 PM in reply to: m.agert
ive just got autocad 2013 to run in windows 8....took 5 minutes....
  1.  right click desktop icon and set compatibility mode to windows 7
  2. Swipe in from the right edge of the screen, and then tap Search.
  3. (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.)
  4. Enter Windows features in the search box, tap or click Settings, and then tap or click Turn Windows features on or off. You might be asked for an admin password or to confirm your choice.
  5. turn on all features for netframework 3.5, and for 4.5
bingo.....somehow it now works !!!!
i dont understand any of the voodoo that makes windows work....but i do remember having to install net framework on previous versions of windows, so i guessed it was importatnt.... i found out its all there ready to go in windows 8, but its just switched off.
New Member
absari
Message 6 of 6 (5,167 Views)
12-17-2013 10:41 AM in reply to: martin_cull
"installation of autocad 2013 worked fine by editing the .ini file, but it crashes with unhandled access violation error!! "+1
