AutoCAD 2013/2014/2015
vikasranga2
Message 1 of 3 (5,327 Views)
Accepted Solution
How to import survey points from excel sheet into AutoCAD 2013?
5327 Views, 2 Replies
06-19-2012 11:55 PM
*Expert Elite*
JGerth
Message 2 of 3 (5,309 Views)
Re: How to import survey points from excel sheet into AutoCAD 2013?
06-20-2012 07:48 AM in reply to: vikasranga2
There's not a 'native' way to do that, but there are a ton of LISP routines that will accomplish that goal.  Most likely you'll want to save the XLS file as a text fILE or cvs, and then use a LISP routine to place points or blocks at the coordinates.
Valued Mentor
TerryDotson
Message 3 of 3 (5,305 Views)
06-20-2012 08:02 AM in reply to: vikasranga2
If you were to consider third party software (especially if your needs are more than just inserting the points) take a look at the MapWorks Points add-on, which will read the XLS file directly.
Also, Excel is a great tool for preparing AutoCAD SCRipt files.  You could use it to create a script file to insert your own point blocks and even populate the attributes.  Here is a detailed related example on how to create layers from a spreadsheet.
Announcements
Need installation help?
