AutoCAD 2013/2014/2015
JamaL9722060
Message 1 of 5 (428 Views)
How to flip the direction of dimension constrains in “block table”,
428 Views, 4 Replies
02-18-2013 11:45 AM
In the screenshot below, the default direction of dimensions constrains are given in the direction of digitizing (by design)
How this direction might be flipped?
For example, in the ArcGIS software, one can see the direction of digitizing as well as flipping it
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
If they perform as Dynamic Parameters do you will need to erase and recreate.
With Dynamic Parameters always move the mouse the direction you want the geometry to move when clicking.
Dynamic Parameters have an "x" at the begnining of the Parameter and a "+" where it ends.
I suspect Dimension Constraints are the same.
(wish I could test.)
JDMather
Message 2 of 5 (396 Views)
Re: How to flip the direction of dimension constrains in “block table”,
02-19-2013 04:49 AM in reply to: JamaL9722060
I haven't tried this with blocks, but do you have a Fixed constraint at the point that you don't want to move?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
JamaL9722060
Message 3 of 5 (377 Views)
02-19-2013 12:19 PM in reply to: JDMather
Thank you for the answer.
Just I wanted to know if there is a way to flip the default direction of dimension constrains
All the best
Jamal
Firefox 20.0,
Kaspersky 2013.
Charles_Shade
Message 4 of 5 (367 Views)
02-19-2013 02:01 PM in reply to: JamaL9722060
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
JamaL9722060
Message 5 of 5 (346 Views)
02-20-2013 12:43 PM in reply to: Charles_Shade
Many thanks Charles for the help.
As you have indicated, the direction of the dimension constrains is controlled by the way we start picking the points of the dimension itself. It is defined from the first point and directed toward the second point
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
